Posted September 22, 20241 yr Owner comment_12473 When you connect an identity provider to your Jira Service Management site, you can authenticate your customers with SAML single sign-on (SSO). Before you begin You must subscribe to Atlassian Access from your organization before you set up SAML single sign-on. Learn more about how to start with Atlassian Access To set up SAML SSO for portal-only customers: Go to Settings > Products. Under Jira Service Management, select Authentication. Select Add identity provider. Follow the prompts to complete the setup. Learn more about SAML single sign-on for portal-only customers View full product update Link to comment https://beta.jimiwikman.se/forums/topic/12132-make-it-easy-and-secure-for-customers-to-log-in-to-your-help-center-with-single-sign-on/ Share on other sites More sharing options...
comment_12473When you connect an identity provider to your Jira Service Management site, you can authenticate your customers with SAML single sign-on (SSO).
Before you begin
https://beta.jimiwikman.se/forums/topic/12132-make-it-easy-and-secure-for-customers-to-log-in-to-your-help-center-with-single-sign-on/Share on other sites
