We removed keyword restrictions when you create custom domains. You will no longer have a fixed list to select keywords for subdomains. Instead, you have the ability to manually enter your own subdomains.
Jira family products have also been given added support. You can now select Jira products from the dropdown menu when you create a custom domain.
To create a custom domain:
Go to admin.atlassian.com. Select your organization if you have more than one.
Select Products > Product URLs.
Select Add custom domain. This is only visible if you have an eligible product.
Review the Before you add a custom domain page, and select Next.
Select which product you want to access from your custom domain.
Follow the prompts to specify your domain. You’ll need to enter two subdomains and a domain.
comment_12477We removed keyword restrictions when you create custom domains. You will no longer have a fixed list to select keywords for subdomains. Instead, you have the ability to manually enter your own subdomains.
https://beta.jimiwikman.se/forums/topic/12136-create-custom-domains-for-your-jira-products/Share on other sites
