Posted September 22, 20241 yr Owner comment_12522 When you use the More + menu, only the fields that are relevant to your project and/or issue type can be selected. You can choose to select those fields to get more accurate search results. Before you start, make sure you’re using basic search (not JQL). Select Filters > View all issues in the main navigation bar. To see issues within a single project, select Issues on your project sidebar. Select More + to see which fields are relevant to your project and/or issue type. Select fields to narrow down your search. View full product update Link to comment https://beta.jimiwikman.se/forums/topic/12180-improved-jira-search-experience-for-project-andor-issue-type-custom-fields/ Share on other sites More sharing options...
comment_12522When you use the More + menu, only the fields that are relevant to your project and/or issue type can be selected. You can choose to select those fields to get more accurate search results.
https://beta.jimiwikman.se/forums/topic/12180-improved-jira-search-experience-for-project-andor-issue-type-custom-fields/Share on other sites
