In the Automation audit log, you can now show or hide entries based on status, making it easier to find specific rule runs and investigate rules that aren't working as intended.
To check it out:
Navigate to automation:
For Confluence automation, go to Confluence settings > Automation
For Jira automation, go to Jira settings > System > Global automation
Select Audit log.
Select Status and choose which statuses you want to filter by.
To check it out:
https://beta.jimiwikman.se/forums/topic/12183-automation-filter-audit-log-entries-by-status/Share on other sites
