We’ve removing the dot menu in Jira to make way for a new and improved command palette.
The dot menu will be removed across Jira from August 19. For a more seamless experience, users will be able to access the command palette to find work, update their issues, access project and admin settings, and more.
To get started with the command palette:
Open the command palette.
If you’re a Mac user, press command + K to open the command palette.
If you’re a Windows user, press Ctrl + K to open the command palette.
Search for commands in the search bar or use a forward slash / to search work.
comment_12526We’ve removing the dot menu in Jira to make way for a new and improved command palette.
More about the command palette
Why are we removing the dot menu?
https://beta.jimiwikman.se/forums/topic/12184-jira%E2%80%99s-dot-menu-will-be-removed-from-august-19/Share on other sites
