There can be a lot of fields to scroll through when you’re creating issues, and we know there are many fields that are simply unused.
We’re introducing a feature that only brings up the fields you actually use. We’ll create a personalized Create issue form for each issue type and project.
All the fields you don’t use will be hidden in a More fields section, so you'll always be able to interact with them. The feature is continuously learning. If we notice you using a previously unused field, we’ll pull it out of the More fields section for the next time.
We’ll automatically turn on the feature to hide unused fields when creating issues, but you can manage it by heading to Personal settings and finding to the Jira labs section. From there, you can use the toggle to opt in and out of the feature.
Get suggestions for child issues from AI
Use Atlassian Intelligence to generate a list of suggested child issues, based on the details of the parent issue.
When you accept a suggestion, a new child issue will be created and linked to the parent issue.
To see a list of AI-generated suggestions:
Open the parent issue.
Select Add a child issue under the issue summary. If you are in a company-managed project and want to create a subtask, select Create subtask.
Select Suggest issues.
We’ll then create a list of suggested child issues which you can accept, edit, or decline.
https://beta.jimiwikman.se/forums/topic/12213-hide-unused-fields-when-creating-issues/Share on other sites
