We're introducing a new feature that allows you to select multiple components at once in the automation rulebuilder and either duplicate or delete them. This change affects both Jira and Confluence, and should help to improve efficiency in the rulebuilder, as you'll no longer need to select each component one at a time to edit them.
To select and edit multiple components at once:
Hold down the Ctrl / Command key and click the left button on your mouse or touchpad.
Select the number of components you want to duplicate or delete.
Once the components are selected, you can use the new menu to duplicate or delete them.
https://beta.jimiwikman.se/forums/topic/12226-bulk-duplicate-and-delete-components-in-the-automation-rulebuilder/Share on other sites
