Emoji shortcuts, based off Halp’s legacy recipes, now use Jira automation’s powerful no-code engine. With this change, admins can manage all automation rules in one place and emoji reactions can be used to edit issues created by Assist in Slack — all allowing for a simpler configuration experience.
If your projects have custom emoji rules, you have until June 4, 2024, to set up similar ones in automation. After that date, the emoji shortcut feature in chat settings will no longer function.
Before you start setting up your new automation rules, keep in mind:
The ticket emoji shortcut used to create issues isn’t affected by this change, so you don’t need to set this up in automation.
You need to set up the eyes emoji shortcut, which assigns agents to issues. Tip: Use the template from the Emoji shortcuts tab in chat settings to quickly set up this automation.
To set up emoji rules in automation:
From your project settings, select Automation.
Select Create rule.
Select Emoji reaction to Slack message as your trigger*.*
Select Turn on rule, name your rule, and then Turn on rule again to save.
To help test your new emoji rules, you can now turn off emoji shortcuts in chat without deleting them:
Set up your emoji rule in automation.
From the Emoji shortcuts tab in chat settings, find the rule to turn off.
comment_12575Emoji shortcuts, based off Halp’s legacy recipes, now use Jira automation’s powerful no-code engine. With this change, admins can manage all automation rules in one place and emoji reactions can be used to edit issues created by Assist in Slack — all allowing for a simpler configuration experience.
Find out more in our Community blog
https://beta.jimiwikman.se/forums/topic/12233-chat-in-slack-emoji-shortcuts-are-now-powered-by-jira-automation/Share on other sites
