We are introducing an enhancement to the drag and drop feature in the Confluence full-page editor, allowing you to nest content within certain elements. This update aims to reduce the reliance on cut and paste actions to improve the efficiency of your content creation.
Single-click nesting: Drag and drop to nest content such as tables, code blocks, expands, panels, and layouts.
Improved content management: The new feature supports nesting of paragraphs containing inline elements, making content organization more intuitive.
Enhanced table interactions: Nest within tables, which represents the highest proportion of nesting scenarios, is now more seamless.
Benefits
Increased efficiency: Reduces the number of steps required to nest content, saving time and effort.
Simplified content creation: Makes it easier to organize and structure content, enhancing the overall user experience.
Greater flexibility: Supports a variety of nesting scenarios, allowing users to create more complex and detailed documents effortlessly.
comment_12648We are introducing an enhancement to the drag and drop feature in the Confluence full-page editor, allowing you to nest content within certain elements. This update aims to reduce the reliance on cut and paste actions to improve the efficiency of your content creation.
Benefits
Â
https://beta.jimiwikman.se/forums/topic/12302-editor-nested-drag-and-drop/Share on other sites
