We're introducing a new feature to Jira and Confluence automation that allows you to clear all selected filters in the audit log with a click of a button. This change will help you to save time and improve efficiency, as you'll no longer need to manually de-select all the selected filters yourself.
To start using this feature:
Open the audit log in either Jira or Confluence automation.
Select any filters you would like to use to filter your audit log.
Once you are done with these filters, select the Reset filters button. All previously selected filters will be automatically de-selected.
Your audit log will now have no filters applied to it.
comment_12672We're introducing a new feature to Jira and Confluence automation that allows you to clear all selected filters in the audit log with a click of a button. This change will help you to save time and improve efficiency, as you'll no longer need to manually de-select all the selected filters yourself.
Learn more about using the audit log in Jira and Confluence automation
https://beta.jimiwikman.se/forums/topic/12326-clear-audit-log-filters-in-jira-and-confluence-automation/Share on other sites
