Posted October 1, 20241 yr Owner comment_12677 If you need to export your Jira issues, you’ll notice a faster and smoother experience due to the following improvements: • Speed and reliability — the export process is faster and can handle a large number of fields and extensive data sets • Tracking and control — you can monitor the progress of your export, and cancel if needed To try it out, go to the Issues page in your project. Select Export, then select a CSV export option. Note that only one CSV export can be processed at a time. View full product update Link to comment https://beta.jimiwikman.se/forums/topic/12331-improved-performance-and-reliability-for-csv-exports/ Share on other sites More sharing options...
comment_12677If you need to export your Jira issues, you’ll notice a faster and smoother experience due to the following improvements:
https://beta.jimiwikman.se/forums/topic/12331-improved-performance-and-reliability-for-csv-exports/Share on other sites
