Posted September 22, 20241 yr Owner comment_12486 This update only applies to organizations that participated in the Beacon or Atlassian Information Security beta. Beacon (beta) will soon be part of Atlassian Guard Premium. Read the blog We’re replacing ‘Beacon’ with ‘Guard Detect’ in the CSV files you export. The name of your groups (such as beacon-admins) will not change. In Atlassian Administration, you’re able to export CSV files for: Managed accounts Audit logs External users User API tokens Authentication policies We recommend checking and updating any scripts that may be impacted by the change. View full product update Link to comment https://beta.jimiwikman.se/forums/topic/12145-we%E2%80%99re-replacing-beacon-with-guard-detect/ Share on other sites More sharing options...
comment_12486This update only applies to organizations that participated in the Beacon or Atlassian Information Security beta.
https://beta.jimiwikman.se/forums/topic/12145-we%E2%80%99re-replacing-beacon-with-guard-detect/Share on other sites
