We’re boosting performance in the issue navigator by changing how the search field works behind the scenes. When using the search field, results will be based on the Summary and Description fields.
Before this change, results were based on multiple text fields such as Summary, Description, Comments, and any custom text fields, which caused results to be slower to load.
If you’d prefer to search using text fields, select More + to view additional field filters, then select Text.
To try it out, head to the issue navigator by going to your project, then select Issues in the sidebar.
comment_12518We’re boosting performance in the issue navigator by changing how the search field works behind the scenes. When using the search field, results will be based on the Summary and Description fields.
https://beta.jimiwikman.se/forums/topic/12176-improved-search-using-summary-and-description-fields/Share on other sites
