You can now link issues to Compass components from any company-managed Jira Software project.
This helps your team organize and track work in Jira against elements of your software architecture cataloged in Compass – so you can understand the impact of that work; prioritize work more effectively; and find the information you need to get that work done faster.
Check that Compass components are turned on. Next to Create component, it should say Compass components. If it says Jira components, select it and switch to Compass components.
Jira components won't be deleted, and they'll still be visible on issues they were previously linked to. You can switch back to Jira components at any time.
Select the Components field, and choose the Compass component you want to link to the issue.
The component and its linked issue will appear on your project's Components page; and you can search for the component in the backlog, boards, and issue navigator.
If you have Compass, and have software components:
Open any issue in your project.
comment_12548You can now link issues to Compass components from any company-managed Jira Software project.
Learn more about Compass components
Switch to Compass components (project admins)
Read the full documentation
Link issues to Compass components
If you don't have Compass yet:
If you have Compass, but don't have any software components:
https://beta.jimiwikman.se/forums/topic/12206-organize-and-track-work-against-compass-software-components/Share on other sites
