Posted September 22, 20241 yr Owner comment_12550 Now you can use filters to search for Jira issues and display them in a list, without leaving the Confluence page. This improvement follows the release that allows you to search for issues using keywords or JQL, and flexibility to add, remove, and reorder fields. How to display Jira issues in a list Start using filters to search for Jira issues: Edit a Jira description or comment. Type /jira and select Jira issues. With Basic selected, use the filters to search by Project, Type, Status, or Assignee. Select Insert issues. This will display your selected issues in a list format you can interact with. To edit your list of Jira issues: Select anywhere on the list. Select the Edit button (left-most icon) from the menu that appears at the bottom of the table. Edit your search query using Basic or JQL. Select Insert issues. View full product update Link to comment https://beta.jimiwikman.se/forums/topic/12208-use-filters-to-search-and-display-jira-issues/ Share on other sites More sharing options...
comment_12550Now you can use filters to search for Jira issues and display them in a list, without leaving the Confluence page.
https://beta.jimiwikman.se/forums/topic/12208-use-filters-to-search-and-display-jira-issues/Share on other sites
