You can now use Atlassian Intelligence to define one or more words in the issue description. The definitions will be based on information found in connected Confluence spaces.
To use Atlassian Intelligence to define words:
Make sure the description is in view mode, not edit mode
Highlight words you need defined
Select Define
Definitions are only available in the description in view mode.
comment_12557You can now use Atlassian Intelligence to define one or more words in the issue description. The definitions will be based on information found in connected Confluence spaces.
https://beta.jimiwikman.se/forums/topic/12215-use-atlassian-intelligence-to-define-words-in-the-issue-description/Share on other sites
