You no longer need to worry about memorizing SQLite syntax for custom formulas. You can use natural language to tell AI how you want to transform the data in one of your columns, and AI will generate the SQLite expression for you.
To try it out:
Add a Formula column or Apply formula step.
Select Custom from the formula options.
Select AI.
Use natural language to describe how you want to transform your data.
comment_12631You no longer need to worry about memorizing SQLite syntax for custom formulas. You can use natural language to tell AI how you want to transform the data in one of your columns, and AI will generate the SQLite expression for you.
To try it out:
https://beta.jimiwikman.se/forums/topic/12286-visual-sql-write-custom-formulas-using-atlassian-intelligence-ai/Share on other sites
