We're adding a new feature to the smart values panel in Jira and Confluence automation. The panel will now have an additional filter called Custom fields, which will contain up to 50 custom issue fields from the current instance you have access to. You can search and copy these custom fields to use them while creating rules in the rulebuilder. Custom fields can be filtered by either the smart value or the untranslated name using text input. We will also display if these fields can be used globally or are bound to a single project.
To start using this feature:
Open the automation rulebuilder.
Select a trigger for your rule.
Add an action that has smart value text fields, such as the Log action, Send web request or Create issue action.
Select the {} button to open the smart values panel.
Select the Custom fields tab to browse available custom issue fields.
You can now copy and use these custom fields in your rule.
comment_12676We're adding a new feature to the smart values panel in Jira and Confluence automation. The panel will now have an additional filter called Custom fields, which will contain up to 50 custom issue fields from the current instance you have access to. You can search and copy these custom fields to use them while creating rules in the rulebuilder. Custom fields can be filtered by either the smart value or the untranslated name using text input. We will also display if these fields can be used globally or are bound to a single project.
Learn more about using smart values in Atlassian automation
https://beta.jimiwikman.se/forums/topic/12330-custom-fields-available-in-the-automation-smart-values-panel/Share on other sites
