Create Confluence whiteboards directly from your Jira backlog
With Confluence whiteboards, you can plan freely and execute quickly. Create a whiteboard directly from your Jira backlog, copy backlog issues to the whiteboard, and plan however you want.
What can you do with Confluence whiteboards?
Use award-winning templates such as a prioritizing and planning matrix
Import Jira issues directly into your new planning whiteboard
Link sticky notes and issues to show dependencies and timelines
Turn sticky notes into Jira issues
Engage teammates with real-time, group editing
Collaborate using stamps, timers, and more
If an admin has three or more issues in their backlog, they'll see the button that allows them to add Confluence and start using a whiteboard. Once a team has Confluence, anyone with access to Confluence — including admins and end users — will see the button on their backlog that allows them to create a whiteboard.
You can remove this button anytime by turning off all product recommendations at admin.atlassian.com. Note: if you add Confluence and then turn off product recommendations, you will lose this button.
comment_12679Create Confluence whiteboards directly from your Jira backlog
https://beta.jimiwikman.se/forums/topic/12333-growth-starburst-jsw-plan-on-whiteboards-experiment/Share on other sites
