To simplify querying your custom fields, we've added a new Issue custom fields table to the "Jira family of products" schema. Each of your custom fields is represented as a column in the table. This also means you can now add multiple custom fields to a single query!
To try out the new table:
Create or edit a visual mode query. Note that the table isn't available for SQL mode queries.
For the query's data source, select an Atlassian Data Lake connection that includes Jira data.
Select Add column to open the schema browser. The Issue custom field table should appear in the list under "Jira family of products".
comment_12689To simplify querying your custom fields, we've added a new Issue custom fields table to the "Jira family of products" schema. Each of your custom fields is represented as a column in the table. This also means you can now add multiple custom fields to a single query!
https://beta.jimiwikman.se/forums/topic/12343-easier-way-to-query-jira-custom-fields/Share on other sites
