In the Automation audit log, you can now show or hide entries based on actions, making it easier to find specific rule runs. For example, you could choose to see all rule runs where the "Send email" action was used.
Navigate to automation:
For Confluence automation, go to Confluence settings > Automation
For Jira automation, go to Jira settings > System > Global automation
Select Audit log.
Select Actions and choose which actions you want to filter by.
comment_12724In the Automation audit log, you can now show or hide entries based on actions, making it easier to find specific rule runs. For example, you could choose to see all rule runs where the "Send email" action was used.
https://beta.jimiwikman.se/forums/topic/12377-automation-filter-audit-log-by-actions/Share on other sites
