If you’re using Jira and have recently added or been given access to Confluence, you'll now see templates in certain issues. The templates will be for relevant types of documents to your issues. For example:
Bug issue type = Known errors Confluence template
Story issue type = Product requirement Confluence template
Epic issue type = Project plan issue type
If you select one of these templates, you'll be able to create the page without leaving Jira. It will then automatically be linked to your issue. After that, you won’t see the templates in any Jira issue.
These templates will appear for up to 14 days after Confluence is first added to your site, after which they'll disappear.
You can remove the templates from your Jira issues at any point using the meatball menu on the placeholder itself.
comment_12727If you’re using Jira and have recently added or been given access to Confluence, you'll now see templates in certain issues. The templates will be for relevant types of documents to your issues. For example:
https://beta.jimiwikman.se/forums/topic/12380-discover-confluence-templates-within-your-jira-issue/Share on other sites
