Posted October 15, 20241 yr Owner comment_12730 Use Atlassian Intelligence to generate a list of suggested child issues, based on the details of the parent issue. When you accept a suggestion, a new child issue will be created and linked to the parent issue. To see a list of AI-generated suggestions: Open the parent issue. Select Add a child issue under the issue summary. If you are in a company-managed project and want to create a subtask, select Create subtask. Select Suggest issues. We’ll then create a list of suggested child issues which you can accept, edit, or decline. View full product update Link to comment https://beta.jimiwikman.se/forums/topic/12383-get-suggestions-for-child-issues-from-ai/ Share on other sites More sharing options...
comment_12730Use Atlassian Intelligence to generate a list of suggested child issues, based on the details of the parent issue.
https://beta.jimiwikman.se/forums/topic/12383-get-suggestions-for-child-issues-from-ai/Share on other sites
